Dec 1, 2025 at 9:18 am If you’re still hugging the edge of the map, sneaking off with a handful of parts, you’re missing the real fun—and the best gear—in Arc Raiders. The big paydays aren’t sitting in random loot boxes; they’re walking around in other players’ pockets. Think of it this way: every fight you win is a shortcut to the best kit. After countless matches of turning cautious roamers into free loot, I’ve learned that speed beats heavy armour every time. Dump the clunky shields. The extra protection looks good on paper, but in practice it slows you down, making you an easy target. Being fast, reactive, and ready to push gives you way more survivability and a better shot at stacking up ARC Raiders Coins. Loadout and Gear That Actually Works Right now, the strongest setup starts with the Combat Mk. 3 augment—those extra slots and built-in health regen are game changers. Match it with a Medium Shield, so you’ve got some defence without feeling like you’re wading through mud. For mid-range, the Bettina AR is solid and stable, especially once you add a recoil stabilizer. Up close is a different story—you’re looking at the Bobcat SMG or the Stitcher. Both will shred someone before they’ve even aimed down sights. Quick slot choices matter, too. Take heavy fuze grenades for flushing enemies out of cover and keep a Shield Recharger on hand for messy fights. If you’re not using stims constantly, you’re not pushing hard enough. Move Like You Mean It Your kit won’t save you if your movement is predictable. The sharper players are chaining slides and rolls, making themselves almost impossible to track. One trick worth mastering is the jump-slide weapon swap. Jump, hit the slide, and swap weapons mid-air—it throws off aim tracking instantly. Oh, and dodge roll should be bound to a side mouse button; it lets you blend rolls with slides more fluidly. Get into the habit of pushing hard when you crack someone’s shield. If it’s yours getting melted, don’t just panic shield—hit that health first, because an empty health bar means instant death no matter how much shield you’ve got coming back. Using the Map Against Them Play smart with what’s around you. If I’m being chased, tossing a Snitch Core or Burner Core behind me can drop ARC machines right onto the people hunting me, turning their advantage upside down. For controlling space, place Jolt Mines at popular spots—like under ziplines—for free kills. Door Blockers work well too; people panic when they can’t exit, and that’s your cue to push in. If farming tech blueprints is draining your patience, you can always speed things up by grabbing the gear you need, including Aphelion snipers and Mk.3 augments, along with Raider Tokens cheap, so you can jump straight back into the fights that actually matter. Arc Raiders isn’t just about surviving it’s about owning every fight and grabbing that high-tier loot before anyone else and u4gm makes it way easier to do exactly that Skip the boring blueprint grind and get the gear you really need fast and secure over at https://www.u4gm.com/arc-raiders-coins so you can stay aggressive and keep racking up those wins. Status: Users Age: 25 City: not specified Registration: Dec 1, 2025 Last visit: Dec 1, 2025 at 9:20 am Topics: 4 Messages: 4 Reputation: 0 Thanked: 0 Send personal message | |
